Adding DC current and AC current by Bias Tee
Sophi21394
Joined Dec 8, 2024
27
I want to combine a 200mA DC current and a 10mA AC current at 1kHz using a bias tee. What values of inductance and capacitance should I use in the bias tee? Also, is there a way to observe the output on an oscilloscope without affecting current supply.
BobaMosfet
Joined Jul 1, 2009
2,211
Do you have a datasheet on the bias tee? I'm curious.
Sophi21394
Joined Dec 8, 2024
27
What is the source impedance for the two current sources?
If they both are reasonably high, then you just need to connect the two sources together.
So no bias Tee needed if impedence are high? What id impedence are low any method to approach and how big impedence should be tovconsider it high?
Sophi21394
Joined Dec 8, 2024
27
Additional - Ac current is holland type
rick.curl
Joined Jul 14, 2020
18
A bias tee is not necessary. The driver circuit already includes everything you need. It modulates the current to the laser diode when you apply the AC signal.
38,859
It you add about a 200mH inductor in series with the DC current output to provide a high impedance to the 1kHz signal, then connecting the AC current driver directly to that connection going to the laser, should work.
Sophi21394
Joined Dec 8, 2024
27
I have bought 100µH to put at end of DC circuit, ok i will bought new one of 200mH. There should be need to put capacitor at end AC circuit to filter DC present in AC?
