Did you turn the trace down to a slow speed before trying the ALT vs CHOP?
yes, what happens in the slow speed is the ALT displays trace ch1 FIRST then displays trace ch2 AFTER. It will flicker back and forth between ch1 and ch2. It is horrible to try to take a time measurement.
In CHOP mode it slices up the waveform in sections of the ch1 and ch2. It is horrible to try to take a time measurement
I thought the ALT mode and CHOP mode is for Oscope that are only for single beam Oscopes which can't display two channels at one time. They use the Alt mode or CHOP mode to "multiplex" ch1 and ch2 onto one trace or single beam
In CHOP mode
Using a single-beam CRT, they multiplex the inputs, usually switching between them fast enough to display two traces apparently at once.
ALT causes the beam to alternate between the two input channels every trigger
Dual mode the signals in channel 1 and 2 appear to be displayed on the screen at the same time
ALT MODE: alternating between both channels on each sweep
In CHOP mode
