Hi, Thanx again Dave.Easy to make the leds work both ways, put the leds in Parallel reversed with one series resistor, across the motor so one led lights up in each direction.
How to do that has been described before.Hi, Thanx again Dave.
This diagram wiring is what I have done at the moment.
However, since the bulbs are on each sides towards the tip, light casts shadow on the other side.
So if it's simple to achieve two bulbs simultaneously, will be good.
Thank you.
Thanks a lot DJ for the diagram.How to do that has been described before.
Use a full bridge rectifier. Use Schottky diodes to minimize the voltage loss. You may need to build your own.
Connect the motor terminals to the AC inputs.
Connect the LEDs to the DC outputs. Use separate current limiting resistors for each LED, and connect each LED/resistor pair in parallel.
You might recalculate the current limiting resistors value. However, 200Ω will still result in a realistic current for the LED.
