I am trying to measure DC current using Hall effect sensor(HCS 300A).
I have to measure 300Amps DC.The sensor gives voltage from M(measure) output,
When the system draws 200Amps ,the sensor output voltage is 4,71V.
If current flows other direction,the sensor gives approximately -4.7V
But my processor operates 3.3V, ADC VREFh can be max 3.3V, VREHL must be equal to analog ground.
How can I convert negative voltage to digital?
