ADC MCP3008 Datasheet
anukalp
Joined Jul 28, 2018
158
I have a project where I would like to use MCP3008 I did some research and I found datasheet. I do not understand timing diagram with respect data transmission ,
Does anyone have an idea? I
Thank you for your help.
ericgibbs
Joined Jan 29, 2010
21,464
hi,
CS has be Set Low at the start of a transmission sequence
The first 5 Clock bits tell the receiver that the MOSI Data should be Read on the Rising edge of the Clock,
Clk 6 is a Dont Care BIT
Clk 7 has to be Low
And the following 9 Clocks tell the receiver to Output 9 Bits of MISO Data prior to the Rising edge of the Clock, to the transmitter.
A Master Slave protocol
Is this what you are asking.
E
anukalp
Joined Jul 28, 2018
158
hi,
Clk 7 has to be Low
E
I am looking for a sequence to read data from MCP3008 or write data to MCP3008
  1. How to tell the chip to get ready to perform a communication.
  2. How to give the time to perform the communication.
  3. How to write data to chip or read data from chip.
ronsimpson
Joined Oct 7, 2019
4,709
anukalp
Joined Jul 28, 2018
158
hi,
Which MCU and language do you plan to use to talk to the MCP3008.?
E
I would interface it with Raspberry pi and I would prefer python
before that I am trying to understand what are the steps write data to MCP3008 and read the data from MCP3008
