AD9833 through a bandpass filter - what happens ?
Status
Not open for further replies.
8dm7bz
Joined Jul 21, 2020
199
I wondered about what would happen if I feed a 20KHz square wave, that goes from 0V to 5V, through a bandpass filter. Does it filter out the DC part and the only part that's left is a square wave oscillating from -2.5V to 2.5V ? And if that's the case, where does the "negative" voltage come from ?
8dm7bz
Joined Jul 21, 2020
199
@ericgibbs thanks for suggesting that, very informative. I understand now that square waves are just a combination of the right sine waves. But I feel like that doesn't answer my question.
I guess the question now becomes: "What happens when I output a 20KHz sine wave with the AD9833, and feed that through a bandpass filter ?"
The problem I have is that the AD9833 has a DAC, which produces only voltages above 0V. But that sine wave looks just like an AC sine wave with some DC offset.
Does the DAC output from the AD9833 through a bandpass filter cut out the "possible DC offset" and go below 0V ?
thanks,
8dm7bz
ericgibbs
Joined Jan 29, 2010
21,567
hi,
OK, post the specification for the Band Pass filter you are planning.
Why are you defining the OPA type as AD9833.?
E
Is this a typo, initially you said: I output a 20KHz square wave
now: What happens when I output a 20KHz sine wave
8dm7bz
Joined Jul 21, 2020
199
So the op amp I had in mind is this one. With some passive components to achieve the bandpass.
But just now I realise something. Could it be that wether or not negative voltages are produced is dependant on the voltage rails I connect to the op amp. So for example, if I power the op amp with a +5V and a -5V rail, the output wave would become negative ?
thanks,
8dm7bz
8dm7bz
Joined Jul 21, 2020
199
Oh, yeah I don't have one. I'm waiting on some opamps to come. I would like to test it myself then. I just wondered what would happen in such a setup.
thanks,
8dm7bz
38,794
The input high-pass portion of the filter will block the DC portion of the input, so the output will have a DC average value of zero, thus giving a plus and minus signal.
The low-pass portion of the filter will round off the rising and falling edges of the square-wave, but it will not be a sinewave.
If you want a sinewave from a square-wave, you will need to use a much higher order low-pass filter than the single-pole filter you show.
DickCappels
Joined Aug 21, 2008
10,661
Agreed with Audioguru Again With an LM358 you would get something more like a trapizoid than a sine.
I'm using a low Q LC filter to clean up the jitter from the 3V P-P square wave out of an AD9833 operating around 60 kHz, to generate a sine wave followed by an LM393 comparator with hysteresis. The filter is intentionally low Q because it needs to be tuned to different frequencies.
It works fine.
Ian0
Joined Aug 7, 2020
13,273
If you're thinking of the Whitmire,Patel and Parizi paper, then the filter is specified as having a Q of 15.9. Frequency response is not specified, but it would make no sense for it to be anything other than 100kHz.
Design utility is here http://sim.okawa-denshi.jp/en/OPttool.php
It makes the square-wave into a sine-wave by filtering out the harmonics.
But (see my other post) why bother when you have just generated your square-wave using an IC that can also generate sinewaves?
8dm7bz
Joined Jul 21, 2020
199
I have to say, that I got a little lost while learning how to reproduce the paper. A lot of new things came up.
I want to thank you for your very detailed Explanation in the other thread. :)
Let's move the conversation over. Thanks everyone for participating in this thread
Status
