AD650 freq to volt circuit power supply question
Tony Elliott
Joined May 8, 2015
158
Hello All About Circuits,
I am looking to power a frequency to voltage circuit using a AD650.
The power connections are new to me, I know how to power a -15 gnd +15 but it only has a +5 connection. Where do I link the -5 on my bench power supply?
I'm guessing gnd between -15 +15 or -15? I didn't want to just chance it as the ic is quite expensive and I only have one.
To see the data sheet
http://www.analog.com/media/en/technical-documentation/data-sheets/AD650.pdf
Dodgydave
Joined Jun 22, 2012
11,301
You link the negative and positive centre terminals together to make Chip ground, then set the psu to +15/-15 and put the 5v supply negative to the Chip ground and the +5v to the chip.
Tony Elliott
Joined May 8, 2015
158
Ok so, the 5v supply negative links with the ground between the -15 +15. could I link them on a gnd rail on a breadboard?
hp1729
Joined Nov 23, 2015
2,304
To logic ground?
