Hum, ok. This is not easy for me to understand. There are too many details I have no knowledge about. Also, I sure did not know that radio amateurs use conventional silicon diodes as zener diodes for those voltages.This is no longer a leak. This is the current breakdown. Do not you know that in the case of a breakdown in a real diode, the current is much more leaky. Some radio amateurs use conventional silicon diodes (with a fairly small leakage) as zener diodes for a voltage of 100-300 volts. This was done in the USSR.
I'm just looking/searching for an easy to use peak detector for higher frequencies starting at about 20Mhz or so.
I'm also trying to find suitable components for this range of frequencies such as OpAmps and diodes!
Thanks for the insight! I like to use my AoE book as a first source of information and go from there to the practice. LTSpice simulation and minimal comprehension of the circuit is what I seek after reading in AoE.D2 stops the amplifier saturating on negative inputs and eliminates the recovery time from that saturation.
D3, at least partially, offsets the voltage drop of D1.
As this point, looks like version B of AoE of the detector is the best of the 3 I presented here. So I want to focus on that one and choose models that I can later compare results from real circuit with the ones obtained in LTSpice!
