Accurate 72 hour timer using IC's
Ikaika Cecil
Joined Jun 27, 2018
Hello eveyone, I'm trying to build a timer for a friend. He wants the timer to go for 72 hours and start/reset with a button. The issue i am struggling with is creating the timer circuit for 72 hours that is accurate. I've seen other posts using different IC's but a lot of them say that the accuracy isn't great for long hours. I know using a micro controller would be easier but he wants the timer to be simple, cheap, and small. If anyone has any expertise or help i would greatly appreciate it.
Thank you.
Bordodynov
Joined May 20, 2015
3,431
A quartz oscillator with a frequency of 32 kHz provides good stability only at a stable temperature equal to the temperature at the inflection point (the top of the parabola) of the temperature dependence. Good quartz has this point about 23 degrees Celsius (if not mistaken), and this is the temperature on the hand (on average). To obtain high accuracy, frequency tuning is necessary, and for this, qualitative private measurers are needed. For a wider temperature range, much more frequent is needed. There are hourly quartz at a frequency of 4.19 .... MHz. Such quartz provides +/- 1 second / day in a very wide temperature range (under the condition of tuning). There are also radio hours that use the signals of special radio stations).
absf
Joined Dec 29, 2010
1,968
Thank you.
Do you need any indication that the clock is running e.g. a single digit 7 segment LED that tells the number of hours remaining? A LED that flashes every minute etc?
Is using CMOS DIP packages like 4060, 4040 OK for you or you can handle SMD to make it smaller?
Allen
35,031
Right at this moment I am building a stopwatch application using an ATmega48. If you need some help with a similar design on an ATtiny or ATmega just give me a shout.
AnalogKid
Joined Aug 1, 2013
12,241
72 hours is 259,200 seconds. With a 1-second clock period, this would take an 18-bit counter string to decode. One option is a CD4060 and CD4040 in series. As above, if you need high accuracy, then a crystal-based circuit using a CD4521 and CD4040 in series will work. Note that decoding the 72-hour mark will be easier if you can tolerate a 1.1% error in the 72-hour period (making it 72 hours 49 minutes). If not, the oscillator frequency can be adjusted, but then calibration becomes a problem.
ak
ebeowulf17
Joined Aug 12, 2014
3,307
So you want to be more accurate, but you haven't said how accurate. Do you need to be within 1 hour, 1 minute, 1 second, fractions of a second? The required level of accuracy changes everything.
Accurate isn't a yes/no question. You have to define the limit, the minimum level of accuracy that is acceptable, and then you can choose a circuit to match.
