AC motor question
Ewood10
Joined Mar 13, 2022
11
Okay I have
bottom two ports - no continuity when off so I feel confident the hot wire will go in one port—but which one?
Top half- both ports always continuity
Ewood10
Joined Mar 13, 2022
11
Great, good cleaning info there.
Still seeking suggestions on switch wiring
Thanks everyone-this is generous help
MaxHeadRoom
Joined Jul 18, 2013
30,788
Okay I have
Use any section of the switch that creates the ON-OFF function?
Doesn't matter which wire to which terminal.
Alec_t
Joined Sep 17, 2013
15,154
I was given, what appears to be, a pretty good used replacement (however amps rating is 12 vs original 16.)
If you are using 110V to power a 2.5HP motor then the current will be about 17A nominal. Your new 12A rated switch appears inadequate, unfortunately. Even the original switch should have had a higher rating.
Ewood10
Joined Mar 13, 2022
11
One more question before I try the switch. In thread#12 I show the old switch—can I assume the heavier carboned side is the hot wire side of the switch? Thanks all
