AC (from main) to DC
Status
Not open for further replies.
wadevva
Joined Sep 9, 2014
7
Hello all,
I am new in this forum so pardon me for any mistake type in this project forum.
I am currently doing this project in powering a string of LEDs which have the output 24Vdc and approx 700mA. As I will be using an AC main power supply, I know that I will need to rectify it to DC before I can do anything. Furthermore, I will also need to power a micro-controller straight after the rectification. So the process is as follow:
AC main ------> Rectifier diode bridge (325Vdc) -------> Power up a 5V micro-controller as well as going to a POWER MOSFET (from calculation the duty cycle will have to be only 6% ) -------> BUCK converter ------->24Vdc to power the LED.
Can I know if this process is correct? Or will I have to use the mosfet to generate a high frequency voltage and use a high frequency transformer to step down the voltage? ( After PWM from MOSFET the voltage will be AC right?)
Thanks!
bertus
Joined Apr 5, 2008
22,935
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Status
