AC be DC Current Coils
Stupdiav
Joined Jul 29, 2011
12
I am need to measure DC current. I was looking at a split core unit like this:
Although the description for the majority of these that I come across only refer to AC Current.
What is the difference between units that can do AC Current and units that can do DC or is there a difference?
35,244
You need a changing current to be able to measure it with a coil. A coil can only measure AC.
To measure DC you need a Hall sensor.
Stupdiav
Joined Jul 29, 2011
12
I somewhat understand that, but I keep thinking how does a Clamp-On meter read DC Current? I really need a “non-destructive" means of measuring the DC Current of a motor. Is there a way to do it with something like this and / or hooking the a coil up to a Hall Effect Sensor?
ronsimpson
Joined Oct 7, 2019
4,843
YouTube is full of "Hall sensor" videos. Simply it is a semiconductor that can see magnets. DC current in a wire makes a elector magnet which a Hall sensor can measure. It also works on low frequency AC currents.
Can not find the picture I wanted but here is a loop of ferrite that goes around a wire. The circle of ferrite is cut and the Hall sensor is inserted in the gap.
Here is a picture of 1/2 of the clamp and the two Hall sensors.
Make a probe video
