Hello all,
I'm in dire need of an adjustable circuit to simulate the square ware of a two wire ABS, so I can trick the ECU into thinking the vehicle is in a skid so the computer will activate the solenoids in the ABS Controller. This way I can bleed the ABS Controller of air. This can be done with a high dollar scan tool that does this function, problem is I'm not that rich. I know that I can simulate the square wave using an the Astable Operation of a 555 timer but after looking in the forum, under the VSS(Vehicle Speed Sensor) Simulator project help post, I'm a little concerned about some of the comments. I quit designing circuits back in 2001 after I had two stroke and have forgotten most everything, but continued reading, I seem to be recollecting some, but not all, so hence forth, I need help. The circuit in the fore mention post is kind of what I think I need, but I'm not sure, so any and all help would be very appreciative.
