What is the best online source for plastic ABS boxes 10"x7"x7"high?
9 Thread Starter 96y Joined May 8, 2019 38 May 18, 2019 #1 What is the best online source for plastic ABS boxes 10"x7"x7"high?
MaxHeadRoom Joined Jul 18, 2013 30,655 May 18, 2019 #2 Bud Industries, I believe Digikey sell them What are they to be used for? Max.
Alec_t Joined Sep 17, 2013 15,117 May 18, 2019 #3 Don't forget to factor in minimum order quantity and shipping costs when deciding on the 'best' source.
9 Thread Starter 96y Joined May 8, 2019 38 May 18, 2019 #4 the bigger ones like this are pricey. Maybe Walmart has some cheap hobby boxes..
T Tonyr1084 Joined Sep 24, 2015 9,744 May 20, 2019 #5 MaxHeadRoom said: What are they to be used for? Click to expand... Super capacitors to replace his car battery. Check out his other posts.
Wolframore Joined Jan 21, 2019 2,619 May 20, 2019 #6 Plastic battery boxes are usually made from polypropylene and polyethylene are designed to withstand acid and gasoline. ABS can react to both. Last edited: May 20, 2019
