Hallo
I wanted some information regarding the function generator. I want to generate the signal of 5V/TTL from function generator. For that I have set the frequency as 1kHz, amplitude as 2.5V. Output is square signal. When I observe this signal on oscilloscope it shows me 5V square signal. But later, when I connect this signal to multiplexer input, then at the input pin of multiplexer shows voltage level of 2.5V.
I want to have 5V/TTL signal at the output of Multiplexer.
Please suggest some suggestion.
Thank you in Advance.
