A2 VFD 3/4hp 3 phase motor problems
case310350
Joined Mar 21, 2019
Have a 220 3 phase motor trying to get working. The wiring is easy. But when I turn it on the motor sounds like its spinning up, but is not moving. Sorta a noisy type of sound, more vibration type of sound. VFD is a cheap A2 series, the typical ones you see on ebay. Went though the programs didn't change much. should I change all hthe 400hz to 60? sems the videos I have watched leave these alone
If you can offer any assistance that would be great.
MaxHeadRoom
Joined Jul 18, 2013
30,772
Is this the Chinese Huanyang VFD?
What kind of motor, 2 pole?, 4 pole?400Hz motor?
Running off of 1ph?
Have you tried running from the keypad?
Max.
case310350
Joined Mar 21, 2019
Yes chinese type vfd, noname ebay search
1.5KW 2HP 7A 220VAC SINGLE PHASE VARIABLE FREQUENCY DRIVE INVERTER VSD VFD US
3/4hp 3 phase motor. Not sure how to tell poles? vfd1.jpg vfd2.JPG vfd3.JPG
