Hello everyone,
This is my first post and i am not an electrical/tronics engineer but rather into another industry.
Problem: How to turn off a simple circuit after a 1 min in the following situation.
I have a water tank which fills up in the morning when we get water from a source everyday. It directly pours into tank and valve is manual. (No pumps etc involved). Problem is overflow.
So I made a simple plastic bottle float and using aluminum foil i managed to create a kind of a float switch. I have a 9V battery connected to a simple 9V buzzer via the float switch.
All is working fine. When tank reaches the level i desire, i get the buzz. Thing is, after i hear the buzz, i manually shut the water valve to avoid overflow. But buzzer won't go off (Level in tank is same) and drains battery and is irritating. As a result now i have an extra job. I open taps and remove some water until buzzer stops.
I can use a board and can manage to solder few components.
It should turn off after a minute automatically.(not 60.00 seconds of accuracy..a min or 2 in short is fine - need minimum components). As of now i added a manual switch in series just after the float switch and i simply turn it off. I sometimes forget to turn it on again in evening and next morning never get an alert with water overflowing.
Thank you.
Thank you.
