A surprising 'solution' to a vexing problem :-)
JoeJester
Joined Apr 26, 2005
4,390
Prior to that app, moving the wifi to a different channel occurred after clients complained about their connections. I know when the set my wifi channel last year, I saw which were in the clear and then set the channel.
Every place I've been that had poor connectivity, it was a crowded channel and the amplitudes were constantly changing ...
Aleph(0)
Joined Mar 14, 2015
597
@Hypatia's Protege
So this is less off topic here than on EHT thread;)
HP Please tell me how to get microwave oven Magnetron to jump to non pi mode.
So I know MW oven magnetron is 10 cavity design so pi mode is mode 5 so I want freq which is far removed from pi mode so it isn't just destructive interference! But it has to not depend on reflected or external rf source! HP I know you did it to get signal in SHF range from 2mnnn Mags so I want to understand how? Tnx:)!
Hypatia's Protege
Joined Mar 1, 2015
3,228
Via elimination of the 'independent variables' (assuming 'monkeying' with the magnets is 'off the table') you've, once again, answered your own question!:rolleyes: To wit: reduce the space charge! -- I'll wager you can figure the 'how' of that for yourself:rolleyes::p
Generally accurate but irrelevant:rolleyes:
Sincere congratulations on your recognition of said liability:)
--Emphasis added--
Just barely! Frequency ≈ 4.64 GHz But at fully 63% power availability and ≈ 91% efficiency of ∏-mode operation:)
All the best
HP:)
Aleph(0)
Joined Mar 14, 2015
597
Hypatia's Protege
Joined Mar 1, 2015
3,228
So you're saying to under-power cathode heater but I say that could damage tube cuz of sputter:confused:?
Cathode 'sputter' is issue of insufficient space charge - So long as sufficient charge is present, sputter will not occur (cathode temperature notwithstanding):)!
My 'attitude' is merely by way of 'response' to your larking about these 'peripheral' topics:rolleyes:!
Very best regards
HP:)
Aleph(0)
Joined Mar 14, 2015
597
HP So are you saying it's like _degeneracy pressure_ of charge that prevents sputter:confused:?
HP So that's ok for sputter but I'm saying there's still major problem of emitter _poisoning_ if cathode is oxide coated:eek:!
HP You know by now I'm studying on Royer circuit again:)! So multitasking is not issue for me:D!
Hypatia's Protege
Joined Mar 1, 2015
3,228
:confused::confused::confused:
Quite despite your seeming insistence upon espying The Pauli Exclusion Principle at work in all manner of phenomena -- The answer is a resounding no!:rolleyes:
Yebut... It's not!:confused::rolleyes: In point of fact they are typically of thoriated W - or, more recently, MAC (metal alloy cathode) design -- I have never encountered or 'heard tell of' an RF heating magnetron featuring oxide emitter material!
Indeed not!:rolleyes: -- and that is (or may be) precisely the problem!;) -- Only time will tell...:cool:
Best regards
HP:)
