a question about signals and systems
circuit975
Joined Jun 13, 2024
43
I have trouble solving the following question related to signals and systems, and I need to plot its graph:
(2t/5) * [u(t) - u(t-6)]
The tools provide a solution, but I want to understand the logic behind how it is plotted.
If anyone knows and can help, it would be greatly appreciated.
thanks..
circuit975
Joined Jun 13, 2024
43
I don't recognize this formula. It might help a lot if you defined the two variables and describe the function of the formula.
this m(t) function is actually a mathematical expression of the unit digit function. and the graph of this is drawn according to this equation. but I'm trying to learn your logic
Papabravo
Joined Feb 24, 2006
22,113
u(t) is the unit step function. It is 0 for t < 0 and 1 for t ≥ 0
By analogy u(t-6) is 0 for t - 6 < 0, and 1 for t - 6 ≥ 0, so it is a translated version of u(t).
circuit975
Joined Jun 13, 2024
43
how do we express the expression 2t/5 when drawing a graph? can you draw and show this with pencil and paper
circuit975
Joined Jun 13, 2024
43
So u(t)-u(t-6) must be a pulse of length 6.
multiplying it by t makes it into a sawtooth ramp.
hmm, I understand you now. when multiplied by t, it becomes a gear, but what about if there were 3 [u(t) - u(t-6)], would there be gears again? or how would it be?
meth
Joined May 21, 2016
316
u(t) - u(t-6) is impulse with amplitude 1 and length(duration) 6.
If you multiply the amplitude with 0.4... you get a pulse with amplitude ____ (fill the blank) and duration ____ (fill the blank).
I dont understand what you mean by gear.
Papabravo
Joined Feb 24, 2006
22,113
I think he means sawtooth. That particular profile on an actual gear would male pretty crappy one at that.
meth
Joined May 21, 2016
316
You are right.. I focused on:
And I did not notice it also multiplies with t before the brackets.
so you have a linear function 0.4t with length of 6.
