Hey there. I'm still new at this but i want some help here. I want to create a pulsing/solid (must be pulsing and switch to solid) led diagram. Ill be using a 9V battery so the voltage must be low. Thanks in advance
Thank you!!!! I appreciate it!!!Hey there. I'm still new at this but i want some help here. I want to create a pulsing/solid (must be pulsing and switch to solid) led diagram. Ill be using a 9V battery so the voltage must be low. Thanks in advance
I want a heartbeat led funtion. Ill guess 1 555 will do but if i want 2 settings like 1 press of a button will set it to a heartbeat function and another press wil set it to solid? Will i be using 2 555's???The OP did say “pulse” not blink.
Yes if they want it to blink then go steady this is easy to do with only 2 555s.
Set the LED to light on the negative output of first 555 then use a second to control the first with the reset line…the first 555 will go low when in reset and light the diode steady.
And I assumed he wanted the entire cycle to repeat...I could be wrong...
Time intervals: R3 - LED on, R4 - LED off.Hey there. I'm still new at this but i want some help here. I want to create a pulsing/solid (must be pulsing and switch to solid) led diagram. Ill be using a 9V battery so the voltage must be low. Thanks in advance
HiHey there. I'm still new at this but i want some help here. I want to create a pulsing/solid (must be pulsing and switch to solid) led diagram. Ill be using a 9V battery so the voltage must be low. Thanks in advance
