oliviawilsonau
- Joined Apr 16, 2025
- 1
You're on the right track—the orange wire is likely a temp sensor or communication line. The mower’s controller looks for a signal from the original Ryobi battery, so without it, it won’t power on. Some people bypass this using a resistor or simple circuit to mimic the signal, but without the PM177-20A-01 datasheet, it's trial and error.
If you're into DIY, this kind of mod is similar to what people do when building custom lawn mower robot setups using scooter batteries. Worth checking out for future projects!
Good luck—hope you get it running!
