- Joined Jul 18, 2013
- 30,771
Early DC starter shown. Now electronic means are used.
AC motors used a Star-Delta starter technique,
If you have ever looked at the top of the cab of a modern locomotive you may have seen some vents running along the length of the cab, Under these vents are huge resistors about 6ft long with fans mounted below them. !But big motors will need resistors which can handle tens of thousends watts I guess!
Unfortunaly I have not ever had opportunity to look at internals of locomotive. But I was thinking earlier to build black smith hardening owen using Kanthal wire when my hobby was blade smith work. I did give up this and used tradititional fire heating whole time. Now after 3 brain strokes ( I am 78 years old) I do more light hand work as motors . I am happy to find out that at early times they had not any better solution than this rough glass melting and hardening owen technique. I tried very thin Kanthal wire with my strong battery just for fun. It has resistance of 20 ohms/ yard. Of course it burned in very short time, I was expecting that.If you have ever looked at the top of the cab of a modern locomotive you may have seen some vents running along the length of the cab, Under these vents are huge resistors about 6ft long with fans mounted below them. ! A project I did a few years ago was converting some old retro loco motives to dynamic braking for running through the Canadian Rockies.
