A/C Low voltage dropping array
Thoms_S
Joined Aug 23, 2014
14
Is there a way I can take a 24VAC output transformer and make it drop to 4 different voltage "legs" [5 total drops]?
I'd like to use a single barrier to pull off: 24, 18, 12, 9 and 5 VAC.
Thank you.
dovo
Joined Dec 12, 2019
72
Thank you.
Some more information would be of use.
What is the voltage tolerance for each of the five voltages?
What current do you need at each of the five voltages?
Are you open to ordering a custom transformer having multiple taps?
28,576
If you are able to rewind the transformer with taps at the desired voltages then certainly it can be done. That is often done with custom built transformers, it is a valid scheme that can work very well.
