Thank you, you are correct. That kit was good for learning soldering but that's about it. Also, one of the components was so how it almost burned my finger.The IC in the Amazon kit has its part number removed then you cannot look it up to see how it works.
A 9V battery is small then it will have a very short life. The battery drains all the time which is why they say to remove it when the light is not lighting.
I think the power jack is the way to go.
