Thanks a lot for your answer! But may I ask, why it wont work?Hello,
The way you show will not work.
You can not put the two 9 volts batteries in series.
Better put the 9 volts batteries directly in the charger.
Bertus
But if I will charge batteries x2 times than normal, it will be the same? I mean, it shouldnt be harmful?Hello,
The voltage delivered by the charger will likeley be to low to charge the two batteries in series.
Bertus
Charger has two 9v battery ports and normally can charge both of them at the same time if you ask this.Is the charger able to charge one battery at a time?
If it can do that then it cannot charge two batteries in series.
That is not what I asked.Charger has two 9v battery ports and normally can charge both of them at the same time if you ask this.
No. Each channel can charge (1 x 2.8V AAA) or (1 x 2.8V AA) or (1 x 9V size).There are 2 channels with 2 LED 'charging' indicators.
Each channel can charge (2 x 2.8V AAA) or (2 x 2.8V AA) or (1 x 9V size).
Regards,
Nandu.
