8x 1 to 8 Demultiplexers
Mancoba1
Joined Nov 16, 2023
30
Thank you very much for your support. I tried to draw the schematic and timing diagram on paper and then use the Eagle program to implement the circuit. My question is whether this is OK or whether there is room for improvement?
All files are the same, just in a different format
Mancoba1
Joined Nov 16, 2023
30
If it is ok, I would also like to simulate the circuit to get the timing diagram. is there a good simulation program?
Mancoba1
Joined Nov 16, 2023
30
thank you... I have improved my circuit a bit and wanted to integrate into LTSpice to simulate but somehow it seems it is not possible to integrate LTSpice into EAGLE or Fusion 360 Electronics. No ULP or the associated symbol is displayed.
The integration of EAGLE with LTSpice has been discontinued since the introduction of the EAGLE Spice Simulator.
ericgibbs
Joined Jan 29, 2010
21,541
Hi M,
Check the existence of the 74hct folder on your PC.
Create a new asc drawing, press F2 and post an image of the pop up menu.
This image is my version.
E
Mancoba1
Joined Nov 16, 2023
30
Thank you very much. I'll give you feedback as soon as I'm ready to simulate it... Do you know where I can find AXICOM - TE CONNECTIVITY Library for Eagle? I've probably looked all over and haven't found anywhere, maybe I've been looking wrong. I am looking for this relay HF3-56 12V.
Mancoba1
Joined Nov 16, 2023
30
I don't know if you have to draw the complete circuit including the relays for the simulation. If so, then I also need to find these relays HF356.
ericgibbs
Joined Jan 29, 2010
21,541
Hi Mat,
Unzip this zip.
Place the 74HCT85.asc and the 74HCT85_Test2.asc in the same folder as your circuit project file and the 74HCT85.asy in the HCTlogic folder.
The Test2 file is just for you to test the transfer
E
Mancoba1
Joined Nov 16, 2023
30
I have been sitting here for hours and unfortunately I don't know what I am doing wrong or what I have forgotten to realize the simulation. Please take a look at this and correct my circuit. When I try to start then it shows me error message. Thank you for taking so much time and being patient with me. I appreciate what you're doing for me.
