80s hifi no longer working
Brocq_18
Joined May 17, 2020
5
I had the radio on one of those big mobile wooden cabinets and it was playing music then I moved the cabinet slightly and since then it's stopped working. Any help on how to fix would be appreciated. I am a complete novice at electrical engineering. Thanks20200517_155716.jpg
35,246
Welcome to AAC!
The second thing that you will do is get the vacuum cleaner out and get all that dust out of there with the help of a soft paint brush.
The first thing that you will do before removing the dust is pretend that you are the first investigative agent arriving at a crime scene. You do not want to disturb anything without proper observation and recording any suspicious evidence pertaining to the crime.
That is, look for signs of stress, smoke, burnt or blown pieces, fragments, bulging capacitor tops, leaked residues, water or moister damage, mold, rust, loose or broken wiring, etc, etc. without touching anything.
Then go to step 2.
Step 3 - Take a good look at that fuse labeled T315mA. Do you see an intact wire inside the glass tube?
Brocq_18
Joined May 17, 2020
5
Hi guys, thanks for the helpful replies.
So the radio had been moved to my new house a few months ago and had been working fine. As I say I moved it about 5cm on its wheels whilst it was on and then silence.
Since then I get no hiss or feedback off any sort. It did used to make a sound when initially turned on even if not tuned but that is no longer the case.
The light on the tuner used to flicker on also at strong frequencies.
The sign on the back says danger high voltage. Does this only apply when plugged into mains?
C614, C613 and maybe a few other have what look like electrolyte leak spots around them. I can't the the main filter caps but I suspect they are affected too. After 30+ years my prime suspects would be capacitor failures.
Audioguru again
Joined Oct 21, 2019
6,826
I think the hifi is old enough to be buried and replaced.
I had my first stereo receiver die at age 26 when its selector switch wore out and could not be replaced. The replacement stereo receiver died at age 28 when its FM stopped working and a few of its switches wore out.
Now music comes from the internet or from my cable TV provider so there are no switches, and I built my own amplifier.
Brocq_18
Joined May 17, 2020
5
Thing is, it died immediately as I moved it. So surely something has become dislodged, the floor it was on is tiled so it may have been a sudden jerk as it rolled over the joint between tiles..
It might be but it's more likely the vibration from moving it caused internal component failure from brittle, thin and worn materials damaged from long years of use.
https://www.mouser.com/pdfdocs/ELNAReliabilityAlumElecCaps.pdf
Maybe it's time.
Papabravo
Joined Feb 24, 2006
22,115
When I was a young engineer, a wise man said to me, that everything I was working on would be in the landfill before I knew it. I thought surely he must be mistaken, but I now see his words as prophetic.
35,246
I would start with the obvious things such as power in, power cord, power switch, fuse.
Are there any signs of life such as panel lights on?
Do you have a test meter?
