Hello Friends...! I want to make a SMPS Charger for 7Ah,12V battery using Buck Topology or Flyback topology. Help me out with some reference circuits or circuit diagrams.
Get a 240v to 12v transformer at 1 amp This will produce AC Put 4 x 1 amp diodes on the two output wires in the form of a bridge. On the positive and negative of the bridge put an 8 ohm 3 watt or 5 watt resistor. Connect it up to the battery and put your fingers on the resistor. Let me know if you can hold it.
Look at the flyback designs in the Webench Designer for a max input voltage of 250Vac and an output of 12V and 0.7A.
You want the designs with output regulation via optoisolator such as the one below.
You will then likely need to add current limiting in the output or change the output regulation to current-mode instead of voltage-mode when charging the battery.
