does this apply to the 74LS47 too? for the pins 3,4,&5?Don’t leave any input control pin not connected.
If the control pin is active high, connect it to GND.
hi, can you please elaborate on this?Hello,
Look at the tables that handle the pins at the datasheet.
Bertus
Yes. In this case, pins 3, 4, 5 are active low. Hence you need to connect the pins to Vcc.does this apply to the 74LS47 too? for the pins 3,4,&5?
How about posting an updated schematic that is cleaned up?I did what you guys mentioned and it works it counts.
Pin 4 and 2 of what?I run into another trouble the minute counter is not counting due to the AND gate, I checked the pin 4 and 2 and it's giving input high. but the AND gate isn't giving an output HIGH. it's 74LS08 and I've tried swapping it to a different one without changes.
the AND gate is getting 5v supplyHow about posting an updated schematic that is cleaned up?
Your seconds and minutes counters are essentially the same but, for some reason, you chose to draw them differently.
I apologize I meant 74LS90That doesn't make sense. Pin 2 is an input and pin 4 is an output
10 counterUnit or 10 counter?
All of the outputs on the minutes decoders have red squares, but they're not displaying 88.
10 counter
That's one of the dumber design decisions I've encountered. Proteus uses red for HIGH and blue for LOW. That makes it easy to differentiate levels at a glance. Especially from poorly focused pictures and screen captures.as for the commonAnodr 7 segments the red indicators on some of them has hint of darker red indicating LOW voltage while bright red means HIGH
the seconds connects directly to pulse generator while minutes and hours needs to get the count from AND gateYour logic is wrong. Explain what you're trying to do.
Was looking at the wrong counters. You should use the output of the AND gate to reset the counter.
Why aren't you having the same problem with the seconds counters?
What are you trying to do with the diodes?
Write down the boolean logic function required and implement it with logic gates.is there any better way for doing reset?
The diode OR gates should be plenty fast for 74LS logic.are diodes not applicable for fast switching?
But, since you're not using the 2-pin reset capability, you can simplify your logic by tying the two reset pins on each counter together and resetting the unit counters even though you don't need to.is there any better way for doing reset?
hey thank you but I tried changing it thinking it would work this time, I wish I could get the best help on this to find a solution.BTW, it was clever of you to notice that since the counters are clocked on the falling edge you didn't need to use an AND gate to decode 9 from the units counters to clock the 10's counters..
Thread starter | Similar threads | Forum | Replies | Date |
BCD Counter 74LS90 Doesn't start at 0000 | General Electronics Chat | 7 | |
A | 74LS90 counter initial value | General Electronics Chat | 3 | |
R | 74LS90 Decade counter | Homework Help | 9 | |
K | 12 hour clock using JK flip flops or 74LS90 counter | General Electronics Chat | 3 | |
L | 74LS90 act like 4017 counter | General Electronics Chat | 3 |
by Aaron Carman
by Aaron Carman
by Robert Keim
by Jake Hertz
