74LS47 Decoder / Drivers
radioshack5209
Joined Nov 25, 2020
68
Hi:
I have a 3 digit display driven with 74LS47s. On one of the displays, the "6" has segment "a" lit and the "9" has segment "d" lit.
The other 2 displays do not light segment "a" for a "6" or "d" for a "9". All segments on the three displays are good. And it
appears that all three sections are wired the same. Is it possible that some of these 74LS47s display a "6" and "9" differently?
Thanks
33,190
Move the driver ICs around and see if the problem stays with the display segment (indicating either a bad display or bad wiring) or if it moves with the driver.
dl324
Joined Mar 30, 2015
18,467
No. Standard part numbering wouldn't be very useful if functionality deviated that much.
From Motorola 74LS74 74LS47 datasheet:
EDIT: corrected typo on part number
