Hey, Ian. I am a subnovice SPICE user, but does this help?Does anyone have a SPICE model for 74HCU04 in linear mode?
I know it's nothing more than a couple of MOSFETs with the gates and their drain joined together.
I think that they simulate 74HC as logic gates (hardly surprising, as they ARE logic gates), but I want to use the HCU04 as a non-linear amplifier.Hey, Ian. I am a subnovice SPICE user, but does this help?
Theremins would be the place to find bizarre uses of parts.I think that they simulate 74HC as logic gates (hardly surprising, as they ARE logic gates), but I want to use the HCU04 as a non-linear amplifier.
I remembered a Fairchild application note on the subject, but whilst trying to find it I came across the SPICE model in Theremin World!
TS is asking about an HCU part. The quote below is from the family specification datasheet.If a 74HCxx IC is biased at half the supply voltage to be a linear amplifier then the current will be massive and the IC will melt.
But it will work perfectly in a simulation that usually allows parts to be badly overloaded.
The Texas Instruments datasheet shows a maximum allowed "transition time" as it heats but I doubt a simulator about knows it.
Obviously, you have never built one.If a 74HCxx IC is biased at half the supply voltage to be a linear amplifier then the current will be massive and the IC will melt.
Interesting stuff. I'd never thought of using them in radio receivers (but I don't do much radio).https://vk.com/wall-45213244_21094
http://www.radioscanner.ru/forum/topic27416-180.html
It's in Russian, so a translator will help you. The second link mentions that when you turn on all six elements, you can't supply 5V power. If you turn on one, you can supply 5 V.
Not so. Plenty in stock at Digikey (for example).The antique "U" one is obsolete and is not available anymore.
Last night Digikey showed they had no stock and it was obsolete for the SN74HCU04 but today they have plenty of them.Not so. Plenty in stock at Digikey (for example).
Just shows the power of an AAC forum.Last night Digikey showed they had no stock and it was obsolete for the SN74HCU04 but today they have plenty of them.
For "absolutely massive" read 25mA @ 6V supply, or 0.5mA on a 2V supply.The Cmos curves show the output current into a resistive load at various voltage losses up to 100% voltage loss caused by a shorted load. You can have an output driving an LED without a current limiting resistor and see the amount of current at various supply voltages.
If a Cmos output is linear near half the supply voltage then if both N-channel an P-channel output Mosfets are both turned on the supply current will be massive.
