"72W SMPS DESIGN -Help Needed"
mishra87
Joined Jan 17, 2016
1,063
I want to design SMPS under below specification-
1. Input - Universal 85-265VAC, 50Hz
Output- 24V@3A
2.
Output- 36@3A
Please help me design it.
Can anybody share me schematic or reference design .
Thanks in Advance !!!
22,084
I think nobody interested on this my post to help me out....!!!
I don't know how you can say that. We have tried to give you the best possible advice. You can take that advice or ignore that advice as the mood moves you. It is however rude and disingenuous to complain that nobody is interested in your post. If you were an accomplished circuit designer and had awesome technical and construction skills then perhaps your goal of constructing an SMPS would seem more reasonable. If you still want to do that you're going to need to learn a few things and you're going make mistakes that result in producing magic smoke.
tcmtech
Joined Nov 4, 2013
2,867
Well if you want help tell us what you are using it for and why you think it that needs a specific custom power supply otherwise if all it needs is a 24-volt source that can supply up to 3 amps then a common off the shelf unit will work just fine.
Lack of sufficient information on your part leads to lack sufficient replies on our part. :rolleyes:
