Hi guys thanks for having a look.
I have here an alternator driven inverter and i have come to wire it up. to the left of the fuse box you will see 3 earth wires (sorry for not using correct colour wires here its all i had to hand)
You will see (2) as in L2 then to the right of that is L1 and to the right of that is GROUND (disconnected).
Now this being a 110v system i am unsure of how to go about wiring up to the breakers.
(I should point out that the red bus wires at the bottom of the breakers were wired in place and none of my doing)
i currently have L1 into LHS of breaker(neutral) and L2 to the RHS and GROUND to ground.
This has especially confused me as i get 130v between L1 and L2 and i am getting 65v between GROUND and L1/L2 and 65v between GROUND and Chassis?
is there something wrong about this?
