5v PWM to a ground trigger
shesacircuitfreak
Joined Nov 9, 2024
Hey folks,
I'm very new to in-depth electronic theory, so I'm hoping someone could point me in the right direction... I'm working on a project car, and I need to take a PWM signal and use it to ground a relay. This signal outputs about 1v in the ON condition, 5v in the OFF condition. When ON, I need to somehow ground a relay. I don't know if there's an easy way to go about this.
Thanks.
shesacircuitfreak
Joined Nov 9, 2024
What else do you know about this pwm signal, like what generates it?
It's the hvac control unit. It signals to the ECM to power the AC clutch on or off, at which point the ECM grounds the relay to turn on. I'm implementing a standalone ECM so need to find a way to mimic the old ECM
DickCappels
Joined Aug 21, 2008
10,661
Did the car owner mention how the voltage was measured? 1 volt RMS would have a higher peak-to-peak value.
Would it be correct to say that the signal will be either ground or pulses (same as PWM with a 0% duty cycle)?
Forgive me, but what is an ECM?
(Electronic Countermeasures in my book).
sghioto
Joined Dec 31, 2017
8,765
ECM=Electronic Control Module I would suspect same as an ECU, electronic control unit.
This circuit or a variation of might be all that is needed.
I would expect a signal similar as seen below.
DickCappels
Joined Aug 21, 2008
10,661
Thank you for the waveform drawings as well as the other information as they clear up multiple questions. A picture is worth...
C1 is not critical. It just need to be large enough to make the ripple resulting from the PWM signal very small. With R1 being 47k and just guessing that the PWM is at least a few kHz, C1 can be pretty small, like 0.1 uf.
shesacircuitfreak
Joined Nov 9, 2024
Wow, that's amazing... I couldn't make one of these myself. That visual depiction is awesome. Great community here; sorry I don't have more accurate information. I plan to purchase an oscilloscope and analyze the signal myself for clarity. I'll have to spend some time looking at this drawing. I'll find some reading material as well.
28,624
Interesting project. If the PWM signal is controlling an AC compressor clutch then it is a very slow signal, second not hertz. So the circuit in post #7 should work very well.
