555 Timer
Bertus2
Joined Mar 20, 2009
5
Hi
Is there a way of generating a fixed frequency signal, but with a variable dutycycle, with a single LM555. The Dutycycle must be variable from about 10 - 90% .
hgmjr
Joined Jan 28, 2005
9,027
Pin 7 is not required since the output square wave on Pin 3 is charging and discharging the capacitor through the diode and resistor network.
hgmjr
Wendy
Joined Mar 24, 2008
23,869
That is a subject for another thread, hijacking is discouraged.
It could be done, but not with a single 555.
SgtWookie
Joined Jul 17, 2007
22,230
Actually Bill, if R2 is 1/10 the value of R1, it will limit the PWM range to what the O.P. requested.
I suggest that R2 is not bogus; it limits the peak charge/discharge current through the diodes to/from C if R1 is at one end or the other.
thatoneguy
Joined Feb 19, 2009
6,359
The schematic shows R2 as variable though, so it too can be zero Ω. The way it's drawn doesn't make it stick out as a pot right away. It should be a small fixed value, not variable.
Wendy
Joined Mar 24, 2008
23,869
It was a recycled brain fart, and we all know how those smell. The base circuit is a variation of this, but the diodes force different charge/discharge paths. Since the resistance always adds up the same, the frequency shouldn't change much.
