555 Timer with Variable Resistor
CraigBolton88
Joined Oct 10, 2008
1
Hi, i am currently undertaking a project and part of it involves a flashing LED. Just looking for any ideas to alternate an LED between flashing at a rate of 1 per sec and then faster up to it being continuously on. I was thinking a variable resistor would do the job? Any help would be great! :).
Wendy
Joined Mar 24, 2008
23,869
How about this...
You probably should break the resistor up between a variable and a fixed value, the fixed value will set your max freq.
For what it's worth, I've built the above circuit (with one LED going to ground) with just one variable resistor.
triggernum5
Joined May 4, 2008
216
Yea, put the minimum resistance safe for a 555 (about 1K is definately safe) in series with your pots.. Otherwise you'll end up frying the 555 each time you dial too low..
