555 Timer Trouble
pchso
Joined Mar 13, 2009
4
Hey guys.
I'm running a 555 timer as a monostable multivibrator. I've gotten it to light an LED for a specified amount of time, but when I hook it up to a 6V or 3V engine, which is what I want it to run, it doesn't work. More specifically, with the engine, when I press the push button that activates the circuit, the engine runs for as long as the push button is pressed but then stops when I release the button.
Although I don't think it should matter, the push button I have opens the circuit when compressed and closes it when open, so I hooked it up to a 7404 hex inverter. I doubt it should make any difference, though. Again, the circuit works perfectly with the LED.
My thought is that the 555 timer's output is high enough voltage to run the LED, but too weak to run the engine. Any ideas on how to make the output stronger? I don't have anything in the control voltage right now.
pchso
Joined Mar 13, 2009
4
Thanks for the quick reply. Any chance you'd teach me how to use said MOSFET or Darlington transistor? Keep in mind I'm completely new to this electronics stuff and that I am trying my best to muddle through this mess.
Bernard
Joined Aug 7, 2008
5,784
Do you know current draw of engine at 9V? With 555 held on it runs so try # 1, add a diode , 1N4002, or similar between pin 3 and motir. If that does not help , as suggested add a transistor, darlington T or MOSFET.Resistor values depend on device. For run of the mill med. power tran. try 1k from 555, 10 mA base current, other R 2.7k
Wendy
Joined Mar 24, 2008
23,857
You don't need the Base Ground resistor, the 555 switches to ground. Something more like this I think...
Instead of the relay use a motor.
Most power transistors will work, unless this motor is much bigger than I think it is. I'm figuring around an amp or so, correct? If so R2 is 470Ω ¼W for R2, and a button for C1.
