I wanted to make a dc motor run for a fixed duration . So I employed a 555 timer in monostable mode and fed the pin 3 output to a relay com terminal and then i connected the motor to the relay .Its a 12v relay and a 12v dc motor.The 555 is perfectly working in monostable mode but the problem is i can't drive the motor on coupling the circuit with the motor by means of the relay.....so i need a solution for this.... secondly can i directly feed the pin3 output to the dc by suitably amplifying the output , sufficient to drive the motor
