The 2N3906 has an Ic of 200mA, so I would make the base resistor 4.7K. Add a 10K pull-up because the 555 won't necessarily source the full +9V and turn off the xstr.
Check that the transistor is actually a 2N3906 and not something else (such as 2N3904).
Check that the transistor is wired correctly, the Emitter should be connected to +9V, and the Collector to the buzzer/LED. See attached:
