555 Timer Delay ON
scbullock
Joined Aug 19, 2023
69
I am attempting to make a delay ON 555 Timer circuit by using a relay.
I used the above circuit and it works, but this is my desirable final outcome:
1) LED OFF
2) Push Button - LED Still OFF
3) Wait around 8 seconds
4) LED ON
This circuit above produces the exact same steps I listed, but instead 1) LED ON. I just want to change it to 1) LED OFF.
Not sure if this link will work, but here it is in action:
https://drive.google.com/file/d/1wfAj86n6-9tYpJ-JQA7Ott-sYF0bAaN0/view?usp=sharing
This circuit will be used to drive a motor (the LED represents a motor).
I'd appreciate all the help.
dl324
Joined Mar 30, 2015
18,477
Welcome to AAC!
Drive the LED high side instead of low side.
If that doesn't do what you want. Add an inverter to drive the LED low side in the original circuit.
sghioto
Joined Dec 31, 2017
8,756
That logic doesn't add up. You can't have #1 and #4. At least not without some additional components.
The LED is either ON or OFF while the relay is activated and vise versa.
When at step #4 how long the does the LED stay ON until back to step #1?
scbullock
Joined Aug 19, 2023
69
Edited: forgot to mention it is in steps. #1 and #4 are not happening at the same time if that’s the way you interpreted it.
Edited:
(Sequential steps)
1) LED OFF
4) LED ON
scbullock
Joined Aug 19, 2023
69
With your configuration, the steps are now as follows:
1) LED OFF
2) Push Button (Relay Actuates) - LED ON for about 8 seconds
3) (Relay Unactuated) LED OFF
Questions: What kind of inverter are you hinting at? I am fairly new to circuit components.
sghioto
Joined Dec 31, 2017
8,756
I didn't. You didn't answer my question. How long does the LED stay ON before getting back to step #1?
scbullock
Joined Aug 19, 2023
69
The relay is going to be connected to a DC motor. So, when the relay is actuated the motor will be on. I’d like if the relay was off before the button press, then when the button is pressed have the 8 second delay, and then turn the motor on.
scbullock
Joined Aug 19, 2023
69
Note for previous question It is a small 3.7V N20 motor I will be using. The entire board will be powered with 18650 3.7V 2500 maH battery.
