555 timer current
Ghina Bayyat
Joined Mar 11, 2018
148
Hi
I wanna ask about the 555 timer
Regardless the circuit how is its output current determined ???
Is it determind by the value of R1 & R2 or one of them in an astable circuit for example ? Or it is not determined by anything and the timer just gives all the current it can that is written in its datasheet ??
Alec_t
Joined Sep 17, 2013
15,117
The current depends on the load attached to the output and should not exceed the rating given in the datasheet.
Ghina Bayyat
Joined Mar 11, 2018
148
Thank u
And if the current in the datasheet = 200 mA for example can i have a load that takes all this current or it will be harder for the timer to work very ? Will it heat up ?
danadak
Joined Mar 10, 2018
4,057
At max load there will be more Pdiss in the part, but if you
are meeting ratings should be fine.
What specifically is the load ? Resistive, inductive, capacitive ?
Regards, Dana.
ScottWang
Joined Aug 23, 2012
7,501
The 555 ic chip can't afford too much heat, so the better is that you just use I=1/3(200) mA, when the load is draw too much current then you can use bjt or MOSFET to do the driver job.
