555 timer Astable Mode output Voltage
eetech00
Joined Jun 8, 2013
4,722
Good Day,
I have made 7 number of 555 timer astable multivibrators on 7 different perfboards with the following circuit to each give output of 0.1, 7, 14, 28, 35 and 42 Hz Frequencies.
Here are the values of resistance and capacitance I used for these frequencies.
0.1 Hz:
Ra = 5.5 kOhm
Rb = 719 kOhm
C = 10 uF
7 Hz:
Ra = 5.5 kOhm
Rb = 1021000 Ohm
C = 0.1 uF
14 Hz:
Ra = 5.5 kOhm
Rb = 510 kOhm
C = 0.1 uF
21 Hz:
Ra = 5.5 kOhm
Rb = 340 kOhm
C = 0.1 uF
28 Hz:
Ra = 5.5 kOhm
Rb = 254.5 kOhm
C = 0.1 uF
35 Hz:
Ra = 5.5 kOhm
Rb = 203 kOhm
C = 0.1 uF
42 Hz:
Ra = 5.5 kOhm
Rb = 169 kOhm
C = 0.1 uF
I made it all and I was finally testing the output voltages on no load. When I tested the 0.1 Hz circuit, initially at Vcc of 12 Volts DC, the voltage between output pin and ground was 11.9 Volts. The voltage was going up and down between 0 and 11.9 Volts every 5 seconds.
Now I tested the 14 Hz circuit. Initially the voltage between output and ground was 5.3 Volts. Then after a few minutes I saw that this voltage go to 11.9 Volts and it stayed there. Whenever I measure it shows 11.9 volts.
Then I tested the 42 Hz frequency circuit. Same as the 14 Hz, initially it showed 5.3 V between output and ground and suddenly after a few minutes it shows 11.9 Volts output and it stays there even if I power off and on multiple times.
Now I have three circuits - 0.1 Hz, 14 Hz and 42 Hz giving an output pulsating Voltage of 11.9 Volts.
Then I tested all the other four circuits with 7 Hz, 21 Hz, 28 Hz and 35 Hz. Initially they showed 5.3 Volts output but they never went up to 11.9 Volts as in the above cases. Two of them went up to 6.9 Volts and stayed there.
So I need some help I am confused and I cannot figure out why this happens. I thought it was the discharging capacitor, I tried discharging it but still I couldnt get it all to give more or less equal voltage output. When I try measuring voltages between the pins for very long, it fries up the 555 timer IC and I lost 3 of them.
Thanks.
Hmm..after re-reading the initial post, it seem like something is wrong with the wiring of the timing components, perhaps when you change the components between tests. Anyway...seems like something is not right with the connections. A breadboard photo would be good..
sab201
Joined Nov 18, 2023
301
Yes you did! Apparently nobody is paying any attention to either post.:(
Ok, I understand that I need an Oscilloscope to see the actual waveforms and their magnitude. Otherwise I could simply be running around in circles, confusing others and wasting time. But the multimeter I was using initially was defective that could have sparked the confusion because it was causing damage to the 555 timers.
Thanks, ericgibbs, eetech00 and all others for your support. Going into the connections would be wasting time I suppose for 7 perf boards since it is a simple circuit and chances of errors are less. Besides the 0.1 Hz board is showing correctly and all other boards have same circuits with change in Resistor, Capacitor values. The multimeter could be unable to show the right Voltage value at higher switching frequencies so it only shows half as Sarah pointed out in post #6 which was overlooked. So that has to be checked with an Oscilloscope.
eetech00
Joined Jun 8, 2013
4,722
Some of those test frequencies are fairly low, might need a frequency counter.
