555 Timer ASAP need to do my presentation
Aikawa Aikun
Joined Sep 21, 2016
5
With the diode in place, the output waveform's duty cycle may be adjusted to less than 50% if desired.
Explain why the diode is necessary for that capability.
Show the current flow for charging and discharging of capacitor, C1.
[/url][/IMG]
http://imgur.com/a/uGVq4
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
Since this is your homework you are expected to show your best effort so far. We can then point you in the right direction. We don't do your homework for you!
Aikawa Aikun
Joined Sep 21, 2016
5
my answer
-the capactor will charge through R1 only because the R2 is shorted out by Diode. because of that, less resistance when charging than discharging.
-current flow for charging is from R1 to diode. current flow for discharging is through R2
is my answer true?
sorry for ask the answer before trying and sorry because my english is bad. :(
it my bad.
18,153
That's correct. Just be aware that the diode drops ~0.7V across itself when conducting. This fact does not affect the qualitative answer, but would be important if you try to calculate the timing.
18,153
The diode will conduct when/if the voltage drop across R2 exceeds the diode drop I mentioned earlier. This means some current is still passing through R2, because there is a voltage across it.
