555 ic troubles. why?
RickSmit
Joined Sep 13, 2024
76
It seems like the transistor is ON, and it also seems like the very fast pulse rate is preventing you from seeing any problems. And you don't have a larger value of capacitor to get a much slower pulse rate. WITH the transformer disconnected.
But there are a whole bunch of big flaws in the circuit as posted in post #16. First, the supply voltage is way too lowf0or correct operation, and using a voltage divider to power a 555 timer IC will assure poor operation. Next, the collector load resistor is too low a resistance, while the current limiting resistor in series with the transformer primary is too high. The adjustments make it better than the first version in post #4, but it still will not work.
FIRST, supply the 555 timer with12 volts DC, and then the evaluation can continue.
i understand the resistor volt divider being wonky thing.... my first was a zener regulator but current was too high and 555 broke. guess i should hv used a shunt regulater where volts is made less by resister and zener but again a resistor is present(unless you can recogmend a better way to get 17.5 to 12v)...
i only have this PSU so my 17.5 1A adapter power is what i must use... and yeah trying to get everthing to 12v but as soon as i connect transistor the power drops to 700mv output. like its automatically only give the transister as much as it needs and not more
question.... cant i take the transistor out? why is it there to begin with other than to invert the output?
RickSmit
Joined Sep 13, 2024
76
laast night i had a thought, may transister only gets what it needs as its the only thin left in that branch, so i decided to make a resistive divider between collector and emmitter for less volts on gate but i had a hunch that the second resistor will act to pull up the transister voltage. and it did. to Vcc voltage...
I will try this:
@A-- i made base resistor higher (470 is convenient as i hav 1w 470's,
@B-- i added a forward diode for accidental testing backwards current, reverse 6v zener to bring voltage down under 6V( maybe i can do a higher zener for lower voltage
@C-- using a 12volt zener as shunt regulator to replace other 470ohm.
@D-- a load after emmitter
@E-- i took out primary resistor
@C1-- 5.6uF is the smallest ''big'' cap i have. according to f=1.44/(R1+2R2)C1 i will have a frequancy of max 28~30Hz lowest 0.013Hz I HOPE... ill replace the cap after im done for hier freq.
i do understand that transforemer output will be LOW thats fine for now. I will let you know how it goes. i will remake circuit completely.
RickSmit
Joined Sep 13, 2024
76
I will try this:
SUCCESS sorta... the transister now gets 3volts. if i probe it at pin3 through the 470 through emitter to ground, i read 3volts and i added a led at emitter to show its working.
BUT NOW the psu,whole thing flashes again, off and on.. whats the problem? if i test the voltage at 22ohm through gate to ground i get full load. i guess the mosfet is not swithing. only has constant voltage at base... right? any suggestions?
also no amount of big cap at c1 makes it flicker slow. i even added a 470uF extra. and having the 5.6uF should hv slown it down enough to see. is the 555 broken?
