555 astable problem
imperatormk
Joined Mar 1, 2011
96
Here is the deal. Recently I built a *simple* circuit with a 555 timer using this scheme:
http://www.google.com/imgres?imgurl...=7PV0TcK-IIr3sgao9JyEDg&sqi=2&ved=0CBYQ9QEwAA
However, when I connect the red probe of my voltmeter on pin 3 and the black probe on GND, I get nothing but constant 0.8V. My power supply is ~12V. I have examined the connections and I can`t find anything suspicious.
R1 = 10K
R2 = 390K
C1 = 4.7μF
Any advice appreciated.
Kermit2
Joined Feb 5, 2010
4,159
A volt meter will not show you the output pulse. At best it will vary the display so it does not settle on a single number. In your case it is showing some average voltage value due to its sampling rate being slower than the output square wave pulse.
You really need an o'scope to see the output waveform.
imperatormk
Joined Mar 1, 2011
96
OK, that is correct. But, I tried with a LED diode and the result was not good (the LED diode wouldn`t flash). Note: The diode has been connected in the right direction (polarity matters).
I am really not sure what can be wrong.
Kermit2
Joined Feb 5, 2010
4,159
Without seeing the schematic or seeing the circuit you breadboarded we are reduced to guessing. Not a very helpful thing - guessing
What did your simulation indicate as the period(inverse of freq) for the output waveform?
A short period would be invisible to the human eye.
imperatormk
Joined Mar 1, 2011
96
Here is the schematic:
http://www.google.com/imgres?imgurl=http://www.m0ukd.com/Calculators/555_timer_calculator/555astable.gif&imgrefurl=http://www.m0ukd.com/Calculators/555_timer_calculator/&h=297&w=370&sz=3&tbnid=rv_ikz9DQ3UxWM:&tbnh=98&tbnw=122&prev=/images%3Fq%3D555%2Bastable&zoom=1&q=555+astable&hl=en&usg=__Dm7-Kwv0Lbkhe3WqqF0d9Ov-UO8=&sa=X&ei=7PV0TcK-IIr3sgao9JyEDg&sqi=2&ved=0CBYQ9QEwAA
As by the online calculator, the HIGH period should be 1.5s (the LOW period as well).
Unfortunately, I can`t post a pic of the circuit, but I think it wouldn't reveal much since everything looks fine and a 800x600 picture taken with cheap camera would not be the key here.
So, if there isn`t anything certain that I should check out (i.e. connection between a IC pin and some element), I guess starting all over would be the best shot.
P.S. Can measuring the voltage between each IC pin and ground (or something else) help here?
Wendy
Joined Mar 24, 2008
23,869
What are the component values? That design can approach 50% duty cycle quite close, but only if R1 is quite low. There is a danger here if R1 is too low in value. What is the current limiting resistor for the LED?
Ron H
Joined Apr 14, 2005
7,063
The component values and schematic are in the first post. The frequency should be low enough to see on an LED, and maybe even on a voltmeter. I'm guessing that our OP has either a wiring error or a wrong component value(s).
imperatormk
Joined Mar 1, 2011
96
Although this post is rather old, I feel that I need to share the solution.
Everything was actually connected well and all, but somehow instead of NE555
I used 741 op amp. Pretty simple, huh?
