Thanks - two channels.BTW: Very nice project! How many channels do you have?
thanks, you mean this board here?I looked at PIC32MZ (EF series) and it has 6 ADC modules which can sample simultaneously @ 3.125 Msps each. It supports high speed USB and can also run at 200MHz. If you get a board with it, it'll be much easier than combining 2 STM boards.
I don't work with boards. I know you can connect the ADC signal directly to the pins (provided they're 0V to VRef+, typically 0V to 3.3V). I don't know if enough analog pins are exposed on this board and whether the PCB layout is suitable. Most likely, there wouldn't be any problems, but it won't hurt to look at the board schematics and layout to check these things.thanks, you mean this board here?
http://uk.rs-online.com/web/p/processor-microcontroller-development-kits/9048455/
Do you know if I can directly connect my conditioned analog signals to the ADCs' inputs or have to get the adaptor boards?
