I am new here can someone tell if I can use 2 legs of 480 volt 3 phase to get 480 volt single phase
C Thread Starter curly Joined Oct 1, 2013 1 Oct 1, 2013 #1 I am new here can someone tell if I can use 2 legs of 480 volt 3 phase to get 480 volt single phase
BillB3857 Joined Feb 28, 2009 2,570 Oct 1, 2013 #2 What is the end use? Why do you want to? 480V is pretty high to be playing with for someone that needs to ask the question.
MaxHeadRoom Joined Jul 18, 2013 28,619 Oct 1, 2013 #3 It can effectively be used as a 1ph supply at 480v. Max.
#12 Joined Nov 30, 2010 18,224 Oct 1, 2013 #4 It can also effectively blow your face off. Get somebody that knows the danger!
sheldons Joined Oct 26, 2011 613 Oct 1, 2013 #5 A 3 phase supply is NOT to be experimented with in any way unless you know exactly what the dangers are and what you are doing-it is very unforgiving of any mistakes ....
mcgyvr Joined Oct 15, 2009 5,394 Oct 1, 2013 #6 These are the types of posts that should only have one answer and be closed.. "Hire a qualified electrician"
