433 MHz garage door remote - 2 way communication
teliocide
Joined Sep 26, 2013
136
If you use these devices to activate something that is out of site you have no idea if "your something" has been activated or not.
My idea it that a second 433 MHz garage door remote can be used at the primary receiver end and when "your something" is activated it activates a "transmit" on the secondary unit. At your end the signal could active a light to indicate all is working all is good.
The question is how to set this up. This is where I require a bit of help.
So when the primary receiver gets a signal and closes its relay, what is the best way to make this activate the secondary transmitter?????
The image it typical of this device
Many Thanks
Greg Pterson
MaxHeadRoom
Joined Jul 18, 2013
30,760
You would need to activate the remote fob in some way.
Either a mechanical solution, or break into the fob and use a relay contact to sub for the fob button.
Max.
teliocide
Joined Sep 26, 2013
136
My intention was to BREAK IN and make connection from the relay output to the fob switch using an optocoupler.
Unless someone has a better idea
teliocide
Joined Sep 26, 2013
136
I have a big bag of Sharp PC 817's I need to dispose of humanely.
