40vdc to 5vdc
cmartinez
Joined Jan 17, 2007
8,768
Is there a simple way to go from 40vdc to 5vdc without the need for transformers or inductors?
I was going to use an LM317, but then found out that its datasheet specifies a maximum of 30vdc at its input.
Maximum power drawn will be about 20mA @ 5vdc....
Or maybe I should just use a zener for this?
Hypatia's Protege
Joined Mar 1, 2015
3,228
you could 'series' a number of rectifiers such that their collective Ef 'drop' brings the input EMF within 'range' of the linear regulator...:D
Although this may achieved with a single reverse-biased Zener, the power (and, hence, reverse current) specification may be 'disappointing'...
Best regards
HP
38,526
I would go with the LM317HV, that #12 suggested, to give you some margin, particularly if you accidentally short the output.
jpanhalt
Joined Jan 18, 2008
11,087
I would not discard the use of a switching buck regulator. There are lots of them available with quite simple applications. Here is just one: http://www.ti.com/lit/ds/symlink/lm2825.pdf
It doesn't even use an external inductor. NB: That is actually quite an old device. So, I suspect similar and smaller regulators are now available.
John
OBW0549
Joined Mar 2, 2015
3,566
Is 40V your maximum input voltage, or is that the nominal? If nominal, what is the maximum? What is the minimum input voltage?
ScottWang
Joined Aug 23, 2012
7,501
If you using zener then count the current about 30mA including the current of zener and load, the formula as below:
Vin = 40V
Vout = 5V, 5.1V zener
I_total = 30mA
R_limit = (Vin-Vout)/I_total
= (40V-5V)/30mA
= 35V/30mA
= 1.167 K
Choosing 1.2K
R_Watts = 35V*30mA = 1.05W, choosing the current limiting resistor as 1.2K/5W.
30,672
Quite a while back I had to design some equipment for a mobile generator application running 240vdc.
The Op-amp circuit was probably no more than 20Ma, I ended up using a resistor, zener and electrolytic there are many of these units in place with no problems to date.
cmartinez
Joined Jan 17, 2007
8,768
Ok... maybe I've just been "drowning in a glass of water" as we like to say down here.
Here's the complete picture:
I want to power up a LED in an optoisolator (H11L2M) that works at a maximum of 30mA. I've used this opto before with a 5V power source and connected it to a 270 ohm resistor to limit its current to below 18mA, and it's been working just fine all this time. I don't know what the emitter's voltage drop is for this device, but I'm guessing it's not too much.
Anyway, I'd now like to feed the same optocoupler's emitter with a 40VDC regulated supply (never mind for now what the conditions on its output are going to be, I've got that covered). So I've been thinking about simply using a resistor voltage divider.
Now according to this site, I've plugged in the values of
  • Vin=40, R1=2200, R2=1800, RL=330.
And the results are:
  • Vout, no load = 18V
  • Vout, with load= 4.5V (sounds good to me)
  • Current through the load = 14mA (sounds good too)
  • Power dissipation at the load resistor = 0.061W
So it seems I'm safe, if I just use this circuit considering the previous values, and I connect the LED in series with the load resistor. I know that the current through the LED will be a little less due to its voltage drop, but I doubt it will reach a level below 10mA, which is its threshold current, according to the opto's datasheet.
Any thoughts anyone might want to share?
