4 phone lines with one cat6 cable
electronewb
Joined Apr 24, 2012
260
Hi guys Is it possible to have 4 phone lines using 1 cat6 cable? Basically I want to use 4 Rj11 plugs on one side of the cable and 4Rj11 box with jacks at the other end of the cable (so I can extend from a box to an actual phone) I believe only 2 wires are needed for a phone line and the contacts on the Rj11 are the 2 middle ones. Is that correct?
Sensacell
Joined Jun 19, 2012
3,786
Yep- but the jacks /plugs need to be 8 circuit RJ-45, not RJ-11
4 pairs = 8 wires = 4 phone lines
Just don't get 'em mixed up
electronewb
Joined Apr 24, 2012
260
Thanks for the reply. What do you mean by 8 circuit Rj45? You mean I need to use Rj45 connectors and jacks and not rj11? What would be the difference? Also this is right that only the 2 middle tabs are used for phone lines?
Thanks
ScottWang
Joined Aug 23, 2012
7,501
yes RJ-45 is an 8 wire jack, but the phones are 6 wire.
Use RJ-45 for the cat-6 then break out the wires to the RJ-11
Phone are 4 wires used in single phone line.
If the TS used telephone switchboard then 4 wires is not enough.
12,167
An RJ-11 connector has six contact locations, but it takes only two (the center two) for a standard POTS phone. Very low-cost appliances such as answering machines used to come with an RJ-11-to-RJ-11 cable with only the center two contacts installed.
Phone circuits are DC. A true analog phone won't care about polarity, but some electronic phones will not work with the wires reversed.
djsfantasi
Joined Apr 11, 2010
9,237
It used to be, that an analog phone won't break dial tone if the wires were reversed. Made dialing impossible!
djsfantasi
Joined Apr 11, 2010
9,237
In your PDF, are all the wires contained in the cat 6 cable?
Will the RJ11 jacks be connected by uncovered twisted pair?
Would you consider a second box where the Ethernet cable was broken out to individual 4 conductor cables for the phones?
Also? Why cat 6? Availability? Cat 6 is more stiff or rigid than cat 5/5e. Is that ok? And more expensive. Both have eight conductors.
electronewb
Joined Apr 24, 2012
260
In your PDF, are all the wires contained in the cat 6 cable? Yes
Will the RJ11 jacks be connected by uncovered twisted pair? I will but heatshring tubing on each pair
Would you consider a second box where the Ethernet cable was broken out to individual 4 conductor cables for the phones? That's the plan each box will get a regular phone cable that will be hooked up to a phone
I have tons and tons of cat6
But would my wiring works?
electronewb
Joined Apr 24, 2012
260
Answer the rest of disfantasi's questions in post 12, then we can start with some options...
I did For some reasons the answers in my post were all over the place
Will the RJ11 jacks be connected by uncovered twisted pair? I will put heatshring tubing on each pair
djsfantasi
Joined Apr 11, 2010
9,237
The wiring concept will work. The devil is in the details. The pairs must go to the correct pins in the jack/plug. Where the pairs separate, be sure to include strain relief. And protect the cables/wires where they enter/leave the boxes. And I'd make sure the polarities are correct, although others have indicated it may not be necessary.
